Colin MacKenzie
4 zones total on a Rainbird system. 2 zones are perfect and my pressure gauge runs at 40psi. 1 zone is not working and no resistance on the solonoid so pretty obvious there. Lastly, zone 2 is releasing some water but very low pressure at a shaky 20psi and can hardly lift a sprinkler head. Pump sounds like it is sucking air as well, but sounds fine and fairly silent on the good zones. This one I am not sure about, so please check my logic.
My guess is since the psi gauge is low the low pressure is not due to obstruction. The gauge is just after the pump and an obstruction would drive the psi higher than usual I think. So this likely means a burst pipe and given that the pressure on the heads is so low and a 1.5HP pump its probably a significant volume. Solonoid is 24v and voltage is good, and pulling the correctly rated 0.5amps. Since another solonoid is gone, possibly this one is too but half working, but I would expect it would behave like an obstruction and psi gauge would be high not low. Am I missing anything?
Given that everything is fine on 2 zones I am not considering the pump, priming or water supply up to the pump to be an issue.
I am highly capable in plumbing and electronics. I can do this stuff and have a lot of diagnostic tools. I have no idea where the the solonoids or piping are other than I know it's not centralized near the pump but each zone solonoid is spread out somewhere in the yard....which is going to be a huge pain to find...so I welcome any cool tricks! (wooden dowsing stick? j/k) Possibly I can just run the zone and then look for a flooded spot on the grass.
Thank you!
Colin
Thank you!
Colin
