The well was drilled about 35 years ago.
When the pump was working (within the last month or so, it didn't appear to have any volume problems. There is a way to allow water to flow out before the tank and it could supply a stream of water from a 1" pipe at least 6ft. That's from about 18-24" above ground. Something may have happened in the last month.
I'm not sure on the foot valve. It was put down when the well was drilled. I know they replaced it at least once just after installing it because they were seeing the same problem (air filling the tank). The Fairbanks pump solved that problem so they didn't do anything else. Now, I'm trying to find a solution.
The drop pipe could be pulled out. It's something I wanted to avoid. If this were a well that wasn't important, I'd be a bit more adventurous but it's the only source of water we have so I'm trying to do the least risky options first.
As a side note, I thought about leaks in the drop pipe and came to the (possibly wrong) conclusion that if the water didn't flow back into the well when the pump switched off that it was likely OK (not leaky).
I don't know if there is a vent. I didn't see anything that looked like a vent on the piece of PVC that caps the well.
I know that it would be good to have someone look at it but we did and one guy said that EVERYthing needed to be replaced. I told him to go away. A 'trusted' plumber did some work on a simple sewer line (above ground). The first time he came, he said he solved the problem. A few weeks later, he had to come back and that time, he actually found the problem We were charged for both trips even though the first one was useless. The reason I'm mentioning this is because there are too few honest people doing service work. I did it for 30+ years (electronics) and never cheated anyone. I knew a lot of techs who weren't nearly as honest.
I'm trying to do this without calling anyone else in. I've learned a lot but am still not quite there.
This would be much easier to me if the pipes had gauges for inlet (suction) and outlet pressures and flow meters but those aren't an option. Virtually everything is done blindly.
