Leaks in new flex gas line for water heater
Ballaw
Seattle
Hi, I am installing a new water heater. Everything is good to go but when I turned on the gas I smelt a little gas. I used a leak detector fluid but didn't see any bubbles. I didn't try starting the pilot. The valve end the flex hose is attached to has a flare fitting (see picture). I didn't put pipe dope on it. Was this correct? On the other end I only applied pipe dope to some of the threads. I read that no dope is recommended but plumber's do it anyway. I used a gas detection device and it went off at both of the fittings even though there were no bubbles. Do you have any advice on what I am doing wrong or how to proceed? Thanks so much!
wwhitney
Berkeley, CA
On the NPT connections, the pipe dope needs to be on the threads at the end, they are the ones that matter. The ones you have pipe dope on probably don't matter. And use a bit more dope.
As to the flare connections, no dope, just very wrench tight.
Cheers, Wayne
Ballaw
Seattle
Cheers, Wayne
Thanks, Wayne. You were right about doping the end threads. It's curious because I read that you are not supposed to dope those at all in case dope gets in the ignitor.
As for the other end the issue was my gas line had a flare fitting already on it and I was attached the NPT end of the flare fitting adaptor that came with the gas line. All's good now and I have hot water!
Old flare fittings don't always fit with the new flex. And I always dope the threads on those.
The new flex should have come with flare fittings for both ends.
