Rman
Master mechanic
I live lakefront and have a shed 8 feet above water level. To it I have a 3/4 hp single 1-1/4 inch pipe to a foot valve which is 2 feet below water level. The pump is 12 yrs old starts right up but with 100 ft 5/8 inch hose pressure is low about 25 psi where the sprinkler is attached must be moved around all day. The water is for irrigation only. Worn out pump or asking too much for its age. Drained for the winter each year. Would a larger pump 1HP bring up the pressure to about 50-60 psi. Currently pump has a 2 gal pressure tank and it holds. The pressure switch came attached to the pump and can only set cut off pressure set at 40 psi any higher and the pump will never shut off
Thanks
Thanks
