Kohler canister valve rotating
Mac1
Katy, Texas
My Kohler canister valve rotates after flushing so the chain tightens up and won’t allow the valve to seat. I can rotate it back into position but after 20 or so more a flushes it does it again. Tried different chain adjustments (tighter/looser) but no permanent fix. What can I do now?
Mike Jaramillo
st joseph mo
the plastic guide rod may not be working up and down freely. hard water can cause a build up. my toilet was getting harder and harder to flush because it was sticking. the force needed to lift the canister up was increasing because of the sticking. I replaced the gasket on the bottom of the canister and while i had the canister out of the toilet, i noticed the guide rod was sticking. after closer inspection it had a buildup of calcium. i cleaned it and put a little bit of plumbers grease on the rod. there are videos on youtube showing how to remove the canister. after i reinstalled the canister, it flushed like it was brand new, silky smooth
Dan2212
Wisconsin
I put in one of these toilets in 2012. Worked great for about 7 years. Then the canister would twist as you describe, and the canister wouldn't seal completely. I changed the gasket.. It had a red gasket that had gotten squishy over the years. I think this caused the canister to stick, and when you pulled it up with the chain, the extra resistance caused it to twist in a wonky fashion, thus twisting the chain. I put in a new Kohler yellow gasket, and haven't had any problems since... April 17, 2020.
