Philip Maynard
You are a hero. Thank you!
Now a very very old thread, but I found it and it helped e when i trouble shot my toilets handle holding issue. So after looking at these post I believe I've solved this issue. Firstly thanks for all the suggestions they helped me figure this out. Now lets talk a little about this issue. These toilets didn't exhibit this issue when new or we would of promptly said thanks but no thank to the retailer that sold us this toilet. So lets get that out of the way right now. Holding the handle for any length of time isn't the solution. Also readjustments generally may get you a little farther down the "now I got to fix this" road. So lets get to the fix. Because this happened slowly until one day we find ourselves double flushing, I immediately thought of hard water and scale buildup. Here in the bay area we have basically cement water. So it was naturally my first thought and for me it turned out right. Now a little about hard water, you may think your water is pristine but remember most water is from underground aquifers or treated surface water (reservoirs) and usually not demineralized. Having said that if you've tried everything else than keep reading. First of all i recommending cleaning out the bowl jets around the inside rim because scale will clog those and make for more maintenance of the bowl. I used a piece of 1/8 inch spring steel (found in a recycled wiper blades) and gently scraped the scale off. This increased the flow to clean the bowl but did nothing to fix the issue. Secondly and more importantly your problem most likely lies in the bottom of the bowl. For this you might want to have a way to pump out the bowl. Now this step requires getting your hands down in there and feeling since where the problem lies you won't be able to see. Now reach down and poke your finger into the water outlet from the tank (round hole that's aimed to the back of the toilet that jets water to bigger oval flush drain). Now is it smooth, without obstruction or stalagmites. Mine was so obstructed in such a way it actually felt like it was unfinished porcelain and actually made that way. Nevertheless less i constructed several chipping tools made from bent screw drivers and proceeded to clear literally chunks of mineralized deposits up to 1/2 - 3/4 inch thick from the jet port. By the way that jet port is relatively smooth finished porcelain so if its rough and scraggly you have hard water scale. I also took 1/4 inch thick pieces from the drain side beyond where I could see using a small hammer and these tools to gently chip these away. Once that was done, the toilet operated like day one. Now I went a step further and fully drained the bowl and added a cup of muriatic acid after chipping and let that work for 10 minutes to get what I missed (do so at your own risk as its probably not recommended
