So not the tank up on top, there isn't enough water going into the bowl. The toilet is apparently one of these new fangled Kohler Canister Flush Valves, so no flapper. The other mechanism is a Korky big looking thing.
Picture!
So basically there is not enough water going back into the bowl portion after a flush. To put is gently, the water level is so low any solid matter that goes into the bowl isn't in water and is exposed. You need to clean up manually after every ...movement... now because it's not in water and not enough water washes it down.
Any advice here? This is a new phenomenon that has been getting worse for a while now, its at the point where I need to find out what to do or I am going to need a whole new bowl!
Picture!
