Kitchen sink strainer with integrated plastic bell?
Dick Rettug
Vancouver, BC
I'm trying to install the drainage on this unusual (for me, at least) kitchen double sink. The pictures tell the tale: rather than being held to the sink by a metal bell and nut, the SS strainer has a plastic bell clipped around the strainer center posthole. The male threads I'm used to seeing at the bottom of the strainer are instead at the end of the bell housing.
I think I'm ok with this plastic approach, except that I had to rely on an adapter (that's a Lesso 1-1/2" ABS-DWV union in the picture) that doesn't seem to quite mate properly. I suppose it may be a bad thread on either fitting, but before my nth try I thought I'd ask the forum if I'm going down the wrong road. Is this system questionable from the get-go, and should I start thinking of replacing the strainer and go old school?
You connect the regular flanged tailpiece to the drain with an ordinary slip nut. It is NOT a "pipe thread". Line up the ribs on the top piece with those on the lower section.
Dick Rettug
Vancouver, BC
I don't think I called it a pipe thread. Are you suggesting that "ribs" rather than "threads" is the proper term? Or am I still misunderstanding?
In any case, the top half of the union is a (thick, plastic) slip nut; and while neither the male or female threads/ribs are tapered I've been unable to get them fully engaged. I think the top threads/ribs are either manufactured to a slightly different pitch (unlikely; though doesn't the UK have a denser threads-per-inch standard?) or subtly damaged. Will have another close look. Thanks for your input.
Kreemoweet
Seattle. WA
That thing you call a "union" - is it an 1 1/2 "swivel plug tray adapter"? It looks to me like the nut is cross-threaded.
Dick Rettug
Vancouver, BC
Just to update: the problem was with the threading on the Lesso ABS-DWV fitting. Solved with a brass slip-ring nut and short flanged tailpiece and washer. Thanks to all for your advice.
