Alexandria Farmer
Converting to a single drain sink. But now the garbage disposal doesn’t fit. Recommendations? I don’t want to move entire drain pip. Should I add an attachment that would curve the drain pipes left?
Not at all what I had pictured.Here’s pic, need to move double wye since directly in the way of drain
How about a photo from about 12 inches above the hole in the bottom of the sink, looking straight down.
Any Pics? Assuming that the wall drain is directly behind the disposal, placing a 45 degree elbow at the wall can be used. Just try not to use any flex pipe.
Sometimes we add a 45 from the wall if needed.
Bout to head to store to get a 45, when I hold up part of the old piece that was a 45 it looks like it might not be sharp enough. I was going to get both a 90 and 45 and see which will be best.Any Pics? Assuming that the wall drain is directly behind the disposal, placing a 45 degree elbow at the wall can be used. Just try not to use any flex pipe.
