Pseudonym
I hope someone can shed some light here for me... and help me find a solution?
Two kitchen-type stainless steel sinks (a Kohler double-basin in the kitchen and an Elkay single basin in the laundry room), both originally installed by a plumber during remodel of those rooms.
After about three years, I noticed the putty under the edge of all three strainer flanges had disappeared from view. It used to be visible as a white ring all around and under the edge of the flange.
I replace the laundry room strainer with a new one, and it hasn't leaked (it's been a year) - BUT there is no visible putty under the flange anymore.
Today I found the non-disposal side of the kitchen sink is leaking. The putty is no longer visible under the edge of that flange, either.
I've never seen this happen in any of the homes I've lived in. What could cause the putty to wash out or dissolve? Should I try again with putty? Should I give 100% silicone a try? Should I try to find strainers that use a gasket under the flange instead of putty or sealant?
Thank you for any help!
