The drain assembly on the large bowl(opposite the one connected to the disposal) is less than two years old. When cleaning the sink and drain yesterday I noticed the drain spin when I was cleaning with a sponge.A couple of hours later I heard a drip sound and when I looked at the underside I could see a drip from the area between the rubber mounting gasket and the sink. Wondering if I can simply remove the drain,clean everything up and reinstall using a seal of new plumber's putty?
Also,which connections do I need to disconnect to allow me to remove the gaskets and retaining nut from the bottom of the sink?
Pictures are attached and thanks for any replies
