Kitchen Island on Slab: AAV Location
CleanSC
Miami, FL.
Fellas.
I have a reconfigured kitchen island which now has been plumbed for a small prep sink. The stub-out is a few cabinets away (but under 5 feet) from the sink cabinet but is accessible via a chase for access to the other workings inside the island.
This house is on a concrete slab on grade so a loop vent is not an option. In my area AAV's are allowed.
Can I place the AAV as shown in the diagram, or must it be under the sink? Again, it's very accessible here as there's a mechanical chase at this location. Bonus question: Where would you put a clean-out? Just under the AAV?
Thanks, all!
That horizontal between the u-shaped part of the trap and the sanitary tee is called the trap arm. Florida use IPC.
You should be good as shown in your picture.
index.php
A cleanout anywhere on that vertical would be good, and below the AAV and above the santee looks like a great spot.
CleanSC
Miami, FL.
Thanks, Reach.
This is a first: a diagram I get right on the first try! Hell I must be learning something around here. ;)
Yes, I somehow had in my head that 5 feet was the longest trap arm distance which is why I had mentioned we were well under that. Looks like I can go as high as 8 which is even better.
Now to figure out the ice maker drain this island. I'm wary of standpipes due to rodents in the DWV system...
The island will contain an ice maker? You may have to pump that drainage, I would think, unless you can put in a floor drain with a trap below the floor.
CleanSC
Miami, FL.
The machine has a drain pump, but those always break so a gravity solution would be nice but the whole setup would have to be above the slab. So I'm SOL there unless we can squeeze all that into 4" off the floor. ;)
I was thinking of just pumping it into the disposer's dishwasher drain connection but thoughts of cross contamination come to mind in doing so... I could do a standpipe but it would need to be tightly gapped at the top (or small diameter pipe) for critters... Should be more sanitary than the disposer, no?
Most places require an air gap for a dishwasher.
What about putting a sink strainer atop your standpipe, or tape a simple screen up there?
CleanSC
Miami, FL.
Good ideas! So that stack will be a busy place, 2 santees, a clean out and the aav on top and a standpipe right next to it. I'll draw up a new diagram tomorrow.
Is there a minimum size of pipe for the standpipe? The smaller the better in this case as it's getting tight in there, hah.
With 1 santee above the other, I think that would be OK under IPC, but it would be better if one of the plumbers who work with IPC to comment on that. I am not a plumber. My feeling is the top santee would be best for the ice machine due to that being a very low flow. A diagram would help present your proposal better.
I don't think there is a minimum. Are you thinking maybe 1 inch? I don't know if you are going to find a pre-made p-trap smaller than 1.25, but maybe there is one and I guess you can make one.
WorthFlorida
Solutions
Orlando, 32828
If the ice machine drain is just for melting ice, maybe a gallon a day, you can use a condensate pump. For drainage, put a sanitee right above the wye for the trap arm. Tee off with a 1.5" pipe and a bathroom sink trap. Extend it (a tail piece) as high as possible under the cabinet and install the ice drain into the open end of the pipe to create an air gap. You'll need to prime (fill) the trap if the ice machine is not yet connected and draining water.
There are air gap devices on the market that you can use. https://terrylove.com/forums/index....sland-on-slab-aav-location.86303/#post-619380
https://terrylove.com/forums/index.php?threads/under-counter-air-gap-for-dishwasher.70822/
index.php
CleanSC
Miami, FL.
I'd like to start ordering fittings tomorrow, does the above diagram show everything correctly? Anything to add or change? Thanks, all!
