I have a Moen 87581, single handle w/ sidespray kitchen faucet. It was installed by me about 5 years ago. I did not install the sidespray that came with, keeping the original sidespray attached.
Problem is low flow when using cold water. When hot water is added (or used alone) the flow increases. First thought it was a cold water supply problem. Looked at the valve (20 year old Jameco with plastic internals) and after turning, the water flow out of faucet became worse, almost a trickle, and I couldn't get it back to how it was so I assumed the valve was bad, stuck halfway closed perhaps.
Then I played around a bit and realized the sidespray works fine. Good flow, even when the faucet flow was a trickle. Rotating the handle back and forth a few times between cold and hot seemed to get the flow back to how it originally was, not great, but not a trickle either.
So these two factors lead to me to think it is the faucet itself. But I don't know what could be wrong. Would it be the cartridge? I've replaced Moen cartridges in the shower faucet but can't remember what the symptoms were. Could it be the diverter? Since the sidespray and hot water seem to work fine and my rotating the handle seemed to improve things, to a point. Or could it be my original assumption that the cold water flow to the faucet is not correct.
Here is an e-p-v of the faucet. I'd appreciate any thoughts. Thank you.
http://www.moen.com/shared/docs/exploded-parts-views/87581pt.pdf
