Is this soffit? Between living and dining room load bearing?
Mike817
NJ
We just had a wall removed that was perpendicular to this soffit? ( not sure what it’s called) this soffit is parrealel to the ceiling joists. I know that normally means it isn’t load bearing but I just want to make sure. Also I just want to level it out with dining room ceiling. I exposed the wood as you can see in the photo and it appears it may have been a nailer. What would be the best way to make this level with the ceiling.
Also the living rooms ceiling is much higher (view where soffit is still covered in Sheetrock)
Thanks for your time.
