SuperGreg
Hello all, we moved into a house a few years ago on a well. I've spent the last few years learning a lot about wells in general but also the quirks of this particular one.
If no water has been used in a while, the water pumping out of the well is cloudy. You can hardly tell if it's coming out of a hose, but fill a bucket and it's obvious, you can't see the bottom. However, if you run the pump continuously for a while (watering the garden, pressure washing, etc) all of a sudden the water pumping out looks like chocolate milk. You can see it transition in the spin down filter.
I have tried to limit water usage for anything that might cause the pump to run long enough to start pulling in the real dirty water, but sometimes it is hard to avoid. We just had the house painted and the painters were pressure washing and ran the water until it wasn't flowing through the filters fast enough to keep up and I couldn't bypass because the raw water was so muddy.
Recently I redid the entire filtration system, and added a pH neutralizer, iron filter, and carbon filter. These all required backwashing and rinsing to get ready, and in trying to get everything ready I used a *lot* of water and started pulling up the muddy water for quite some time. I finally gave up and came back to it the next day.
I've noticed that the raw water (again looking at the spin down filter) seems to be clearer than usual now. So my question is, would it help to run the pump for a while to clean the well out, or is this harmful and something I should avoid?
I know that everyone is going to suggest drilling a new well. That would be great, except for the cost and the chances that the new well will have the same problems. Here is the material in the ground described by the well report:
0 - 3 ft Brown topsoil
3 - 7 ft Brown silt
7 - 78 ft Gray silt w/some gravel
78 - 82 ft Fine gravel
82 - 84 ft Gray clay
If drilling a new well, would it be worth it to have them try to keep drilling deeper into a cleaner material? I've talked to a couple well guys and they both said the location I'm at is very problematic. The neighbor is on a surface well, and just had a well drilled and didn't hit water.
3 - 7 ft Brown silt
