Is it against code to place a nat. gas forced air furnace in a plastic pool?
Molo
Cold New York
As assurance if the sump pump fails, we are considering placing a forced air furnace in a plastic pool or stock tank to protect it from potential water table rise.
Is there a code that doesn't allow this?
Thank you in advance for any replies
Stuff
Pennsylvania
No electrical code other than being poor workmanship. Better to put it on a stand. In the old days bricks, blocks and poured concrete pads.
Molo
Cold New York
It is on concrete blocks, but it is still not high enough. It can't go any higher because of the vent pipe height limitations. I know this isn't an electrical question, but I thought it may apply if it were an electric hot water tank.
Stuff
Pennsylvania
Furnaces can be mounted horizontally and hung from the ceiling (unistrut or similar) which can solve vent issues. Probably not an option but many have theirs installed in the attic.
WorthFlorida
Solutions
Orlando, 32828
A battery back up sump pump is the only way to go cost wise. Get a generator for extend power outages. Using a plastic pool is a problem, how do you get it under the furnace? You'll need to remove the furnace. Two is, should the water raise high enough, the pool will act like a boat and may lift the furnace up and damage the duct work, or worse yet break the gas pipe, etc.
