Looking for some advice with anyone with experience in this area.
Here is my situation. My lawn is not looking to great and I am trying to figure out the best option on how to automatically water my lawn. I plan to install an irrigation system.
Some basic information first. Yard is mostly St. Augustine grass. I might have to till and sod but I sure am not going to do that until I have an automatic irrigation system. I live in Northeast Florida and the soil is mostly sand. My first goal is just to water the front lawn and my front lawn is around 3000 square feet and from what I have read it needs 1” of water a week. In my city you can only legally water 2 days per week. So I calculate it would need 1860 gallons of water a week. But there is tremendous loss when using a sprinkler system so it actually would need considerably more water to achieve that 1” watering goal. I should add for my bushes and plants I have already installed drip irrigation. So I am trying to figure out the best option to automatically water my lawn without spending thousands on an iron filtration system:
1) Use City Water - The problem is city water where here is very expensive as they charge more than twice the water bill for sewer, so I estimate it would be well over $100 to water the front and if I eventually wanted to water the back yard I would be looking at $300 a month.
2) Have City Install a separate Irrigation Meter - The cost would be over $1,000 for the city to just connect to the city water and install the meter and then they charge a minimum water fee even if you use no water that month. Would take years to recoup my investment and it is still an expensive option.
3) Use my Well Water - This is the option I am most interested in. I have a shallow well and the rust is bad. I ordered off a kit to see exactly the amount of rust, but there is a neighbor that uses there well and there is rust everywhere. Now if I go with the well water there are several options:
a. Sub surface - This option seems interesting as it uses less water and I would not have to worry about the rust issue, or at least I think it would not be an issue. But it is hard to find a lot of good information on Sub Surface irrigation. I see some sites that talk about it providing uneven watering so you ended up with patchy looking grass. Also I worry about sediment clogging up the emitters and then having to dig up the yard again to fix it. This option would be the most difficult to install, but if it actually worked perfectly would be the least expensive option.
b. Chemical Iron Remover System - I see the SprinkleRite system, but wonder how well that would work, how long it would last outside in Florida Summers and how much chemical I would have to add to remove the rust. This might be the simplest and not too expensive option to try and see what happens.
c. Iron Filtration System – This would be the most interesting option if I could find a reasonable priced system. If I could find one with a backwash and filter material that last a long time. So far what I have seen is all over $1000 and most costing thousands. Is there any sub $1000 Models that work well?
d. A natural iron aeration filtration system - Again this is one that is hard to find a lot of information on and how to build it. It is not even clear to me how I would control the well pump to pump the water into the storage tank and I am not going to have some huge tank. So the goal here would be for the well water to pump water into the storage tank and mix with oxygen to allow rust to form and fall to the bottom. I am just not sure if this would work and how much rust it would remove. I have to put out at least 2000 gallons of water a week and the flow rate cannot be so slow my well pump is cycling. Let’s say I had a 50 gallon storage tank. Would the rust from the well water be removed fast enough to keep up with the irrigation needs. This sounds like an inexpensive natural fix but I am not sure it would actually work.
