David Schmidt
Hello, everyone.
My wife and I will be ready to move into our new home in a few months. The water analysis for our well shows the following concentrations:
We will likely install a point-of-use RO unit under the kitchen sink for drinking & cooking. My question has to do with point-of-entry whole house treatment to reduce the iron level in order to protect our gas water boiler, other plumbing, and the RO unit.
The iron seems to be ferrous iron as the water is clear and colorless, and nothing precipitates out after the water sits for weeks (I’ve even aerated the water for a day with a fish tank aerator and no precipitation).
I understand that a cation exchange water softener would normally remove the iron, especially at our 1.67 ppm concentration. However, I’ve been told that because the water has so little hardness, softening may not work effectively. Here is the quote:
“Resin has a limit to the amount of iron loading it can handle. Under normal conditions its about 600 grains per cubic foot using 10 lbs of salt per cu ft. Most softeners are geared towards 6 or 8 lbs to be more efficient so it is more like 400-500 grains per cu ft. The rule of thumb formula is you need two grains per gallon (gpg) of hardness for every ppm of iron. (include manganese content with iron) This allows dispersion with the iron on the exhausted resin to make sure it is removed during regeneration. Too little hardness and the iron will eventually foul the resin and make it useless. 2 ppm of Fe/Mn needs to have a minimum of 4 gpg of hardness. I have always errored on the side of caution and like 2.5 gpg per ppm so I would want 5 gpg of hardness in this example.”
I’ve been unable to confirm this requirement for a 2-1 ratio of hardness-to-iron in order to prevent resin fouling in the softener. Can anyone confirm this information for me?
If this is true, it seems like our best option for iron removal would be a tank system using an oxidizing resin, possibly with air injection. Or perhaps a Pentek RFFE20-BB radial flow iron reduction filter. Any thoughts on these other options would be greatly appreciated.
Thank you very much!
TDS 610 ppm
Conductivity 970 uS/cm
Iron 1.67 ppm
Hardness 7.33 ppm as CaCO3 (0.43 gpg)
Calcium 2.22 ppm
Magnesium 0.432 ppm
Manganese 0.0135 ppm
Sodium 222 ppm
Sulfate 98 ppm
Chloride 8.6 ppm
Alkalinity 410 ppm as CaCO3
pH 8.65
Corrosivity -0.249 (Langelier Index)
Iron 1.67 ppm
Calcium 2.22 ppm
Magnesium 0.432 ppm
Sodium 222 ppm
Sulfate 98 ppm
Chloride 8.6 ppm
pH 8.65
