pls2000
A question for someone with more experience with these things than I have
https://www.homedepot.com/p/Mueller...tern-Compression-Coupling-160-004HC/100155616
If this joins pipes that are essentially free on both ends, neither pulled out of the coupling nor pushed into it, and holding the normal 60-70 psi city water pressure, will the pipes be blown out?
I need a way to join temporarily two pieces of 3/4 steel pipe, one of which is old enough that trying to break open a fitting would be like trying to win the lottery.
++PLS
++PLS
