Having an issue with iron bacteria bio fouling, which quickly clogged big blue 2-stage particulate and iron filter. The iron bacteria also leaves small amount of oily sheen and clumpy film in toilet tanks. Well has been previously treated by driller for “iron algae” with industrial strength hydrogen peroxide, with no long term benefit.
Well water is 6.5 ph, with iron level between 0.3 and 0.5 ppm, although the primary concern appears to be the iron bacteria which clogs filter and fouls 300 gal cistern inside the house. Chlorine injection system is already in place will be retained to help oxidize iron and kill bacteria. Looking to add a backflushing iron filter.
Questions.
1) vendors selling iron filters do not agree with respect to requirement for a “contact tank” to allow time for the chlorine to kill the iron bacteria, after the chlorinator and before the backflushable iron filtration tank. Is that advisable/required?
2) vendors also disagree for the need to adjust ph to at least 7.0, in order to generally filter iron effectively, is that advisable/required?
3) Does presence of chlorinator to “pre”-oxidize the iron prior to the iron filter lessen the importance of the ph needing to be 7.0 or greater, if in fact 7.0 is advisable?
4) at least one vendor warns against using air-injection type iron filter with iron bacteria issues as the introduction of O2 will lead to iron bacteria growth in the filter media itself and fouling of thta filter. Any feedback on that one?
Many thanks in advance for your time to assist.
Dan
Questions.
Dan
