Interaktiv Shower Column - cool to hot, no in-between
Rossn
Denver, CO
Hi All,
I have a Hansgrohe Interaktiv shower column (like the one shown below) with thermostatic mixing valve. I'm guessing it is from 2005
Recently, the temperatures started malfunctioning... when turning the temperature control, it goes from low 90's to 107 or so, with a minute adjustment. Extremely difficult to get anywhere in-between.
I tried to re-calibrate the temperature adjustment, but that didn't seem to help. Is this a failing thermostatic valve that requires replacement or something else?
Many thanks!!
Tuttles Revenge
Yeah. Sounds like the cartridge has failed. Hansgrohe will likely send you a replacement if you call their tech support line.
Rossn
Denver, CO
Thanks, Tuttles! I called and they confirmed the cartridge should be replaced and gave me a part number. Unfortunately, due to the age, they wouldn't provide it as warranty or complimentary.
