Kiko
I plan on tapping into an outlet and pulling 14/2 ROMEX®® through a light switch box and terminating in a reinforced ceiling fan box in the center of my bedroom ceiling. This is a finished (drywalled) room with no attic. My question is, How can I do this with the minimum amount of damage to the drywall? I have a wire puller, 4" holesaw for the fan box, and Dremel/Rotozip for the light switch cut-out.I think I will need to make a rather large hole near the outlet box in order to push one end of the ROMEX® into the outlet box. Is that correct? Pulling wire straight up shouldn't be much of a problem (perhaps a small hole where the wall meets the ceiling), but how do you guys pull wire across the studs? Do you make a gash in the drywall with a rotozip set at a depth of 1/2", then push the ROMEX® into this gash and staple the ROMEX® to the exposed studs after perhaps notching them out a bit?
