JaCkaL829
Hello,
As my title says, I'm experiencing higher water pressure in my house after I replaced some water supply lines. I cut out a section of 25-30 feet of older supply lines in my basement that was sheetrocked over. Every other supply line is 1/2" copper (some M some L) that feed my kitchen, bathrooms, etc. I removed the old supply lines since I though it was galvanized steel, but it turns out most of it was older brass supply lines. Anyway, now that I put in copper type m, I've been experiencing an increase in water pressure. I also notice now when my toliet stops running, or a faucet is shut off quick I'm getting water hammer. I believe some of that can be reduce by finishing up my job with adding straps for the longest run (20 feet), but I'm wondering if I should be concerned with the increase pressure? I've never had this problem, and I don't have a pressure reducing valve or anything like that on my house line.
Any information would be greatly appreciated, I feel like I've experienced water hammer before, but I've moved and replaced lots of water lines, that it's hard to keep track. I've never used those water chamber arrestors that go on the washing machine.
