HVAC takeoff advice needed
Giantsean
Hi All,
At long last I am fixing to install two additional return registers to my system which has been struggling to breathe and move air for about eight years. The return trunk is 8" H x 16" W. As I have lengths of 6" and 7" flex leftover from the install, I want to put them to use. The 6" run is not a concern as I have space, but the 7" takeoff is raising some questions. You can see from the pics the joist bay from which the flex will drop down. Originally I had hoped to take a 7" round starting collar straight into the 8" side, but as you can see there is a lot going on in this area.
Assuming a 7" starting collar is not already too big for an 8" duct, I might have to move the condensate line up a bit (above the wires and tighter to the joists). I could also attach it (or a square takeoff) to the bottom though it's not ideal. The top is not accessible at all.
Last option is I could just go 6" on this one though I really want to maximize the airflow. From my understanding there's no such thing as too much return air.
Thanks for any advice on how to best do this!
Giantsean
It is a 2-ton Trane TAM7. Filter is 16" x 20". the main trunk return duct is the 8x16 for it's entire length (around 40'). I should add there are already four return ducts total in the system with following register box sizes:
6 x 10
6 x 12
4 x 14
4 x 14
(all are 6" or 7" flex except for one 5x14 which is directly over and connected to the trunk duct)
I am looking to add two more return registers both 6x12 one using 6" and one 7" flex. Besides the excessive suction on the return side, I am trying to get better air circulation in the kitchen and breezeway, both of which are next to each other and neither have a return. The kitchen has a dining area w/ a space far enough away from the cooking areas (>10ft) so it should not be an issue - checked this w/ the bldg dept.
Giantsean
Thanks! As far as airflow, no issues running a return straight into the trunk duct at a 90? (Vs more of the "wye" or 45 bend.. not sure what the term is for ducts...)
