I've got to rough in for the tub filler, which is a 1042BP Newport Brass with a 3/4" female end on the back. I don't have the actual equipment yet, it's on order, so I don't rightly know how I'm supposed to install it.
It looks like I'm supposed to install a 3/4" female fitting inside the wall, and then use a brass nipple to connect the two.
My question is, how do I do this correctly? If I'm not dead-on on the rough-in, which requires knowing how thick the wall+tile is, then I could end up having a fully tight tub filler with a gap between it and the wall. Or, I could have it hit the tile before being fully tight, or hit the tile and not be facing the right way!
I do a lot of home repair and construction around my house, but it usually is of the "make it up as you go along" kind and not so much the precision work.
