How to convert a "no hole" tub overflow drain to a 1 or 2 hole
Tiffany Herndon
Florida
Hello, I need some help with my bathtub situation. I just bought this house, and I have never seen an overflow drain like this before..
I'm trying to use this adjustable overflow drain cover that i purchased to make the water deeper for when I take a bubble bath.. and I can't figure out how or what to mount the 2 screws that are needed to install the new cover. Ill attach pics..
The solid chrome cover with one single screw on the bottom is what's installed now.. i took that off, to find a threaded PVC with another removable threaded piece attached.
The one i want to be installed has a black foam back with 2 holes for mounting screws.
I bought an adapter bar, thinking it would fix my issue, but it also needs to be mounted with 2 screws.. so I'm stumped..
Please help.
Thank you
Fitter30
Peace valley missouri
Thanks for replying,
But the set up on my over flow drain doesnt have anything to screw the 2 screws needed on that pic that link you sent..
Not sure how id be able to use that
That black plastic part has threads the metal flat piece fits in the teeth screwed on the threads of your tub fitting metal piece towards the tub. Then cover plate attaches to the flat metal. One thing we don't know if your threads and theirs are the same.
Tiffany Herndon
Florida
Oh really? I did not know that.. i thought it looked like my same set up, only with a black piece.
Ill go back to that link and see if the measurements are provided..
Thank youu! Ill let u know if it works for sure:)
Tiffany Herndon
Florida
I wanted to add..
I have already bought that little flat metal piece.. but my threaded piece that screws onto the overflow pipe, doesn't have the teeth it would snap onto like the one you sent.
If i purchased that one.. will that allow me to use the overflow drain cover that i bought to replace mine?
Its an adjustable one that has 3 settings, which are closed, half closed, and fully open..
And it has 2 screws needed to mount through the flat metal piece I'm assuming. .so how or what would the screws be screwed into?
https://www.amazon.com/dp/B01ET78ZTC/ref=cm_sw_r_cp_apa_fabc_7P1WFb1F64TD1?_encoding=UTF8&psc=1
This is what I'm trying to use on my tub
wwhitney
Berkeley, CA
I don't see how that overflow could possibly mount to your tub and work properly. It's designed for the gasket on the back to be up against the tub surface to make a seal. But you have a pipe projecting out through the overflow hole, and it will hold the overflow cover away from the tub, so it can't seal.
Cheers, Wayne
Fitter30
If you can find a PVC plug that matches the id of the overflow drill the center out then slot the sides and cut down the metal bracket.
Tiffany Herndon
Florida
Cheers, Wayne
Yes, i thought that I would need to cut down the PVC that's poking out from the tub, and make it even with the tub.. but i wanted to make sure before i messed it all up lol
So if I did that.. would it work u think?
Chucky_ott
Active Member
Ontario
There's probably a gasket behind the tub and that nut you removed is keeping the overflow tight against that gasket. So you might need to keep that nut there to keep a good a seal.
Tiffany Herndon
Florida
If you can find a pvc plug that matches the id of the overflow drill the center out then slot the sides and cut down the metal bracket.
Ok, so I followed what you're talking about until the part where u said to slot the sides and cut down the metal bracket..
Why am i cutting down the metal bracket?
Sorry.. I'm trying to understand lol
Tiffany Herndon
Florida
This is what it looks like with that threaded nut thing removed from it
