JRowley
Newbie here.
I'm installing an Aprilaire 800 steam humidifier. Included is a saddle valve I'm supposed to pierce a 3/4'' cold water line (PEX-A/Uponor) with. From there, a 1/4" O.D. copper line into the unit's inlet, which also takes a compression fitting.
The problem? It leaks, and I've tried twice.
The solution should be to tee off of the 3/4" line with 1/2". Or, replace the saddle valve with a tee and then some sort of adapter/valve and run the 1/4" O.D. copper line into that (so all I'm replacing is the saddle valve).
But, I can't figure out how to go from a PEX-A tee to whatever can take a 1/4" O.D. copper compression fitting.
I'm assuming I need a ball valve that's 1/2" for the PEX-A side, then the other side needs to be... what? Because I am unable to find any ball valves that are 1/2" x 1/4".
What am I missing?
Thank you
What am I missing?
Thank you
