Hot water tank removed: Need advice on why water continues to drain, not leak, from disconnected hot water tank line BUT only when washer is filling?
bettajune
Texas
Hot water tank removed for replacement. New 3/4” ball valve replaced but left hanging there unconnected and doesn’t leak. So far so good…
THEN when I turn on the washer with COLD water, it fills normally EXCEPT, water starts running out of the 1/2” pipe which should be for hot water that would be exiting the hot water tank IF there was one connected.
I’m trying to find out if something else is wrong somewhere else before proceeding on with installation of the new hot water heater…. Any scope of help would be certainly appreciated. Thank you so much!
GReynolds929
Active Member
WA
The washing machine cold is crossing over to the hot side. May be normal may not. Is the washer set to cold only? Rinse and wash?
