Hot water not what it used to be
Banjo Bud
Active Member
South Carolina
Ok I have another question on this dip tube. If it’s bad, and pieces of plastic are in the tank, then even if I replace the tube, that doesn’t get rid of the plastic. So maybe a new tank is best.
Phog
Active Member
Rochester NY
There is foreign stuff inside of every water heater that's not brand new -- mineral scaling , rust, dissolved anode. I know you've flushed yours regularly, but it's difficult to get everything out. A few pieces of plastic (or even an entire broken off section of tube) won't hurt anything. I still think you've gotten your money's worth out of a 12yo water heater, but I don't think plastic pieces should weigh into your decision.
Banjo Bud
Active Member
South Carolina
Thanks Phog. I think I’ll just get a new tank. I’ll pull the anode and save it. Then I’ll look at the dip tube just so I know.
Banjo Bud
Active Member
South Carolina
Ok guys, I got a new 1225 cartridge from Moen and installed it in my shower. Same problem exists. When I am in the shower with the mix just right, and then pull the knob straight out for more flow, the mix changes. It gets cold. It’s not a big problem because I simply rotate the knob for more hot and then it’s ok. But is this an indication of an underlying problem with the water heater? Do you guys think a new dip tube will fix it? Both elements are good. Do I even need to worry about it? Should I just keep on keeping on until the tank fails completely or leaks?
How about comparing the water
That cartridge is not the pressure-balancing part. See https://terrylove.com/forums/index.php?threads/old-moentrol-which-cartridge.4244/
Your symptom does not seem to go along with a bad dip tube. The dip tube would tend to limit the time that you got hot water, and your problem seems to be flow-related. You could check the temperature of the pipe out of the WH as you adjust your shower. Non-contact thermometers can be pretty cheap today.
But I would be wondering if that pressure balancing thing could be your problem.
A pressure balance spool valve normally does not have any effect on normal operations unless it is stuck. Its purpose in life only comes into play if the SUPPLY pressure coming into the valve were to change. If, say, the cold water pressure were to drop when someone flushed a toilet, turned on say a hose bib, etc., it would lower the volume of the hot to match the pressure coming in with the cold, and within a small margin, keep the OUTLET water TEMPERATURE the same (keep things in balance)...it has no effect with changing the outgoing volume except, potentially in one case that I can think of. With a tankless system, some of them will adjust the output volume based on trying to keep the temperature the same. That effectively drops the pressure, and that could affect things a bit. It shouldn't be an issue with a tank.
