JasonY
Long story short, my public water supply from street is at 110 psi, and I don't have any pressure reducing valve currently in the house. Am planning to install one. I understand that even the PRV has a bypass valve, I need to also install an expansion tank on the cold line downstream (house side) of the PRV. My problem is as follows:
The water coming on from street has quite a bit coarse sediment, I can see it from the whole house water filter housing (translucent). Aside from the sand particles, there are larger pieces 1/16 to 1/8 inch. Apparently they go thru water meter just fine. But I worry so much about the sediment clogging the PRV if I install it upstream (city side) of the water filter. My water filter is an aqua-pure PT11 model, with max pressure of 125 psi. So far so good, knock on wood, but there's little margin. The PRV I ordered is a Wilkins 70XL, which hasn't arrived yet.
1. in your experience, is it OK to install the PRV upstream (city side) of the filter?
2. is there a good, heavy duty (150psi) water filter I can buy so that I can install PRV downstream (house side) of the filter?
3. what's the best solution for this scenario?
Thanks.
Thanks.
