jack frost
I recently washed a 2" well to 60'. Water level is less than 10' deep. I need to use this well to fill up a pond, so I need to get max GPM. Pressure doesn't matter at all. No access to electricity so either the pump would need to be gas, or I can run a generator. Ideally, the pump would pull less than 30 amps so that i can run a quiet inverter generator. Right now, I'm pumping water with a 3" trash pump with a reducer that is borrowed. So the question is, what would be the best pump setup for max GPM?
