Help with DIY Water Softener + Chlorine System
powerplyer
San Jose, California
Hello long time lurker on this forum first-time poster.
Here is my issue. I currently have a Kentico Classic (quad system in my house). It has been inactive for over a year due to constant issues and being a money pit (~16 years old). I am looking to get a new system and looking for advice for a complete system. I have called a few water softener companies in the bay area however, they seem be expensive relative to how much the equipment cost vs. buying a DIY system and hiring a plumber.
Here is what I am trying to accomplish with my DIY:
Control Valve either a Fleck 7000XLT or Cleck (after much research these seem to be the best options)
Require a 64K GPG tank(s) (Family of 5 adults with 4 bathrooms)
Would like to use the best resin (read on this form about 10%)
Brine tank (Prefer Square)
Would like a system which supports KDF-55 or Carbon (preferably in separate tank or built in seperator) (Chlorine Removal)
Don't want to touch system for 10-15 years besides adding salt. (reliable systems)
If you making recommendation can you please provide links to sites. My current systems is hooked up to 1" copper fitting. BTW I have been reading the forum for the past week trying to piece together a system however, nothing to seems to be the correct fit for my application.
Thank You in advance for the help.
FYI I am on city water with a hardness of 18 gr/gal. After doing calculation, we consume about 60 gallons per person per day. I know the 64K system may be overkill, but planning for the future.
ByteMe
Semi-Pure awesomeness!
Scio Ohio
Hmmmmm, family of 5 with 4 bathrooms. Any high flow fixtures?
I think you need to size for SFR (service flow rate) verses total hardness grain removal capacity.
Just guessing, but maybe like 16gpm?
I think that is more like a 3 cuft (96k) system.
And I agree, a Fleck 7000 or clack WS are the best valves.
powerplyer
Thanks, no high flow fixtures. Most of the installers said a 40K is fine but wanted to be safe with 64K. The problem with Fleck 7000 or Clack WS is the ability to add a separate chlorine media.
This system seems to fit the bill perfectly (Fusion NLT Hybrid Professional-Grade Metered Water Softener With Chlorine & Chloramine Removal (20GPM)) however, I do not know this brand from uswater systems.
Coconut shell activated carbon has lifetime of 3 to 5 years. Coconut shell type is what you want for this job.
ByteMe
Scio Ohio
You don't want to mix medias in the same tank, unless using something like a media guard setup.
Suggest 2 tanks; one a backwashing carbon filter and then the softener.
ditttohead
Water systems designer, R&D
Ontario California
A separate tank for the chlorine reduction and softener would be a better choice. The system you mentioned uses a valve and adapter that is not manufactured by Fleck or Clack, probably the tanks too, hard to say for sure. I would not recommend it.
