ShadowAviator
Here's a question for you electricians.
I am planning out the lighting circuits in my small house in the country, and I am trying to figure out how many lights to put on each circuit. I know to calculate the wattage of the fixtures and use that to help get the numbers.
My question is, what wattage do you plan for on the individual light fixtures? I bought 4 100 watt fixtures, however I only plan to use LEDs. I believe those LEDs only run 15 watts. So do you plan for a 100 watt fixture or a 15 watt? If you plan for a 15 watt fixture, you could almost wire the whole house on one circuit. But if you plan for the old 100 watt bulbs, then you will be somewhat limited.
I guess I am curious what is the common way to plan out light circuits in new construction, today. How much do you take into consideration the new LEDs?
I don't plan to ever use anything other than LEDs (unless there is something else more efficient that comes along). I just don't want to create any headaches for myself down the road.
