heldmacm
Hello,
Yesterday, I noticed a faucet that has a garden hose connected to it was leaking at the hose. The hose is nearly brand new, and there didn't seem to be any punctures in it, so I disconnected the hose, and sure enough, there was a steady stream from the faucet. I confirmed the faucet handle was all the way off, which it was, and I've since shut off the water to that faucet, and that stopped the drip.
I noticed a portion of a black washer at the bottom of the faucet (where the water was dripping from), and I removed it with pliers. I don't know if that was the issue, but it certainly wasn't doing me any favors. Anyway, I suspected that I needed to remove the stem valve in the event that, or one of the washers on it, needed to be replaced, and I'm having a difficult time getting the handle off. In most DIY help videos I've seen, there is a screw holding the handle in place, and you simply unscrew it to remove the handle. However, the type of faucet I have is different, as the pictures should show. There is a nut holding what appears to be a bolt in place in lieu of the screw. I successfully removed the nut and loosened the packing nut under the handle, but I have no idea where to go from here.
The first picture shows what it looked like before I did anything, the second picture illustrates what I'm looking at with the nut removed, and the last two show the loosened packing nut, as well as how the faucet is connected to the stem. I could really use some assistance to determine 1). Am I approaching this the correct way in attempting to remove the stem valve, and 2). If so, what do I need to do in order to remove it? If I'm not going about fixing the leak the right way, I'd certainly like to know that, too.
Thanks in advance for your help.
