I would appreciate feedback on my proposed drain and vent layout for two new bathrooms on the main floor. Is it better to have the drain right below the vent wall or angle the drain away from the wall to keep the run as straight as possible.
or
Also, is it okay to wet vent both toilets off Lav #2 if I use a 2" vent there? The wet wall is only 2"x4" and while it is not load-bearing, I don't see a way to run anything bigger than 1.5" vents across the stud bays.
Thanks in advance for your guidance!
Les
or
Les
