All, for the last couple of years, I have had to gradually turn my water pressure down on my 1/2 hp convertible deep jet well pump. I had to turn it down from 30/50 to 20/40, at the pressure switch, or the pump would just continue to run. When we would do laundry the pump could not keep pressure and would drop to low pressure and would surge trying to keep up. Eventually, the seal went bad and started to leak.
So, the other day, I bought a new 1 hp pump thinking this would solve my issue. I installed it and the same thing occurs. When i took a shower today the pump ran so low it lost prime.
I figured that it must have something to do with the ejector in the well or a clogged screen on the foot valve. (The water pressure remains at a constant when I turn the pump off at the breaker, so I imagine there isn't a leak in the system-I have also sprayed soapy water at all connections to the pump and piping and have found no leaks) I spent all morning digging a pit to try and find the well head (it is buried in the ground). I eventually found it and am confused how to continue pulling the lines.
The first pic (well 4) shows the giant crater I had to dig to reach the well head.
The photo above shows the 1 1/4 line that runs horizontal into the basement of the house and to the deep well jet pump, the 1 " line is directly below it. I assume these nipples thread out (you can barely see the threads in the picture) which would disconnect the horizontal lines from the well. However i am afraid to do this. I am not sure how the vertical lines connect to the well.
I am guessing this square fitting is for a wrench and it unthreads a cap to prime the vertical line?
Below the top portion of the well head are three bolts in a triangular pattern. I assume I must remove these to pull the well lines. If that is the case, how are the vertical lines connected to the well so that they make a union with the horizontal lines?
I am just afraid to undo the horizontal lines and then the vertical lines fall into the well. Have never down something like this before, so I am being extra cautious. Thanks for the help.
Caleb
Caleb
