Help identifying plumbing in garage
chow2006
Tennessee
Hello all,
I’m new here.
I’m planning on installing a whole house water filtration system. I’m in a newer house, and there are two shut off valves beside the tankless gas water heater.
I’ve tested both shut off valves (circled in red in the photo) and they work. I know the pressure regulator is circled in yellow.
but I’m trying to figure out where I need to cut into the existing pex pipes (and add a couple tees) to add in the water filter — so that the water is filtered before it gets to the water heater or goes elsewhere in the house.
And I’m not sure what the three pipes going into the wall are ...
Can anyone shed some light on this for me?
My guess is that the lower ball valve is incoming and the top one is after the PRV ( pressure reducing valve ).
Perhaps the top pipe in the wall is the one to the water heater? The middle one to the rest of the home? The bottom one incoming?
chow2006
Tennessee
Thanks Terry.
with the water filter I want to install, I would like to install it after the PRV (to prevent damaging the water filter) and before it goes to the water heater (to help prevent scaling in the water heater).
So there’s my conundrum in not knowing what each of the three pipes going into the wall is.
There is NO WAY to tell what the three pipes are without being there and doing some testing. The arrow on the PRV will tell the flow direction, which would be the first step in the diagnosis. In this area, the bottom one would be the incoming, the middle one would feed the fire sprinkler system and the top one would supply the house, but that might have absolutely to relationship to your area or situation.,
chow2006
Tennessee
Thank you, HJ!
I checked the directional arrow on the PRV — it goes up.
If I turn off the bottom ball valve, no water anywhere (main shut off valve).
If I turn off the top ball valve, no water anywhere inside, only running water then is an exterior faucet (sprinkler system).
So that let’s me know the top pipe is the one supplying water to the inside of the house.
