Help Design Laundry Stack
Jjherm1
Midwest
Hey all,
Redoing my laundry stack, fixing all of the previous owners mistakes.
House was built in 1959 with a cast iron p trap buried under the concrete. It’s eroded, leaked, clogged, and causes the washer to overflow.
Plan is to cut out the old p trap, use a fernco to a long turn 90 to get vertical. From there use a sanitary tee to go back horizontal, using the top of the tee as clean out access. That will go back to a 45 like there is now to get parallel with the wall.
See any major issues or changes for the better in the way the rest of the drain/stack is put together now? Suggestions?
Edit: I know the AAV isnt code. I'm sure its intended setup was a wet vent, but I'm not sure that is sufficient.
Your pictures did not work.
AAVs are code in most of the midwest.
Jjherm1
Midwest
Jjherm1
Midwest
Cast iron is out. Holy plugged. Went ahead and plumbed it up. I plan on framing up the wall eventually so if i did something wrong I’ll redo it then
I like it. You might want to put a support for the standpipe near the top to deal with any mechanical stress.
Jjherm1
Midwest
Reach,
good to hear, thanks. Yeah I’ve got some temporary supporters in there now. Once i get it framed up I’ll get it really secured.
