Hey all,
Redoing my laundry stack, fixing all of the previous owners mistakes.
House was built in 1959 with a cast iron p trap buried under the concrete. It’s eroded, leaked, clogged, and causes the washer to overflow.
Plan is to cut out the old p trap, use a fernco to a long turn 90 to get vertical. From there use a sanitary tee to go back horizontal, using the top of the tee as clean out access. That will go back to a 45 like there is now to get parallel with the wall.
See any major issues or changes for the better in the way the rest of the drain/stack is put together now? Suggestions?
Edit: I know the AAV isnt code. I'm sure its intended setup was a wet vent, but I'm not sure that is sufficient.
