Noke
Hello everyone,
I purchased a house that had a MQ3-45B pump installed in line with the main city water. Within the last few months I have noticed that pumps cycles on and off repeatedly, but it doesn't do it every time. I believe I have narrowed it down to the cycling occurring after small water draw offs. After doing a little bit of research and speaking to a few people it seems like the problem might be the take up pressure bladder being under inflated.
I turned off the main water supply and unplugged the pump then drained the lines. I then knocked off the back cover and unscrewed the bladder/pressure tank (Part Number: 96565367). Water continued to drain out of the pump as well.
I unscrewed a little cap from the top of the bladder/pressure tank to expose what looked like bike valve. I was told to inflate the pressure tank to roughly 25 psi. Unfortunately I can't get the tank to take any pressure. I have tried a bike pump and a small compressor (the type found in a battery pack you would keep in your car). When I use a pressure gauge to try and check the pressure from that valve, I get no reading at all.
The tank seemed to have water in it so I shook it to try and get out as much of it as possible and tried again. The tank still will not take pressure. When I hook the compressor up to it and set it for 25 psi it immediately cuts off.
Is there something that I am missing or doing wrong? Is this bladder/pressure tank bad?
