Mark Bloxom
Terry, I recently saw the article you wrote on this controller. I have one and it is stuck on 100 PSI, the controller won' t change. You commented that the variable speed pump could be hooked straight to the power supply. If so what would the pressure be without the controller, wouldn't it still be running wide open? I really need a very low flow because its not that good of a well and it just runs to a 1000 gallon tank that I use for watering grass with another pump. Also could I put a variable speed motor controller on the power supply and adjust flow/ pressure that way.
