Hello helpful people,
I have a situation that is not sitting well with the wife. Her blonde hair is turning green/blue after about 2 months.
Background: Problem was really bad when we first moved into house that is on well water. Installed water softener and it got better (it used to turn it green in about a month). Eventually it is still turning it blue after about 2 months.
Setup:
Do any of you have any experience taking care the this problem?
Thank you all for your suggestions.
Setup:
- Well head into pressure tank (Copper Piping)
- Pressure tank into Sediment Filter (~150 ft Copper Piping I believe)
- Sediment Filter into Water Softener (Ptex)
- Water Softener into UV filter (Ptex)
- UV filter to house (Copper Piping)
- Hardness
- Pre Softener = 18.1 gpg
- Post Softener = ~1
- pH
- Pre Softener = 6.5
- Post Softener = TBD (waiting for test kit)
- Low pH is corrosive to copper piping pulling out the blue hue?
- If this is the case, someone suggested installing a Soda Ash System in the well pit before the pressure tank. This way pH will be treated before reaching any copper pipes.
- Can this blue hue be filtered out any way instead of lowering pH?
- Mineral build up in Hot Water Heater?
- Any other thoughts?
