Galvanized steel to PVC in bathroom: plumbing vent + tub drain
Dan
Nebraska
great thanks, seems much sturdier. but how would i connect the straight tubular coming down from the tub?
edit: the idea being the tubular ptrap allows me to take the 'trap' off, or twist/move it around to get at a clog, a clean out on top of prevent gas coming back up. woth that pvc trap, i would have to cement/glue one end so i wouldnt be able to use it as a clean out, correct?
wwhitney
Berkeley, CA
well this is the problem: i'm not sure what to call the size of the galvanized steel. it is ~1.25" inner diameter / ~1.75" outer diameter. but 1.5" solutions couplings fit it.
That's probably 1-1/2" galvanized. The OD should be 1.9", same as the 1-1/2" plastic you're using. The ID was originally 1.5", but as the steel rusts it can accumulate on the inside and reduce the ID. So it is worth replacing as much of it as is possible.
Now if the OD is 1.6", that's 1-1/4" galvanized, which would be a problem.
On the trap style (tubular, solvent weld + threaded, or solvent weld only), I don't have an opinion, I'll just point out that the first two options would let you open up the trap, the last option would not.
Cheers, Wayne
  • Like
Reactions: Dan
Dan
Nebraska
Cheers, Wayne
wayne, thanks. i found the no-hub coupling that fits: fernco P3000-150. you are correct, it is ~1.9 for the outer diameter.
i will stick with what gagecalman posted above: pvc p-trap. 1.5".
horizontal pipe will be 1.5" solvent welded
vertical will have the 1.5" threaded adapter solvent welded accepting the vertical 1.5" tubular from the bathtub/shower
wwhitney
Berkeley, CA
gagecalman posted two options for the p-trap: one where the two pieces thread together (and the inlet and outlet are solvent welded), and one where the two pieces solvent weld together. In conjunction with the trap adapter, the first option would let you remove the U-bend of the trap, while the second option would not.
I've never used tubular on a tub waste and overflow, so I have no opinion.
Cheers, Wayne
  • Like
Reactions: Dan
Dan
Nebraska
Cheers, Wayne
thanks for clarifying and i should have been more clear in the post:
i will be going with the option that allows me to remove the 'u-bend': https://www.lowes.com/pd/Charlotte-...ia-PVC-Schedule-40-Hub-P-Trap-Fitting/3132661
wwhitney
Berkeley, CA
That alone doesn't, but coupled with a trap adapter for the tubular drain from the tub, the u-bend can be removed. Or are you saying that on that style of two piece trap, the two pieces don't separate and are captive?
Cheers, Wayne
Dan
Nebraska
Cheers, Wayne
yes youre right about the the u bend having two trap adapters
this is what i am doing, im assuming this works?
Dan
Nebraska
Cheers, Wayne
dry fit photo
Dan
Nebraska
Cheers, Wayne
heres the final job
I see that now.
Still required precision. Good work.
