So I bought a fleck 9100 SXT a few years ago and installed for whole house. Since they advertised 4PPM iron removal I thought it would be a good fix but turns out it's not great at removing iron. I also have sulfur and magnesium. So I have come up with a plan to separate the two tanks and use one for active carbon and one with the resin pellets for cleaning my pool water when the TDS gets too high.
The problem is, the second tank has an unknown tube size and the adapters I keep buying are too small (o-ring) and will only fit on the first tank. I think this is the correct one now but I don't want to buy another part that doesn't fit. Can anyone verify that this part will work to just adapt the second tank to an NPT fitting in order to remove the first tank? Thanks,
https://www.water-softeners-filters...VbMj0vYhC_5JS3cG9HHQ9aCRqrGTVxPgaArtyEALw_wcB
