topnitroracer
Hello Everyone.
Just in the last week I had my Fleck 5810 softener system installed. Since then, I have been noticing the volume of water it is registering is very high. For reference over 90 days I usually average about 9000 gallons of total household water use. This is softened water plus un-softened. The flow usage on my Fleck 5810 has been showing about 350 to 450 gallons used each day. Last night it said I used 70+ gallons while I was sleeping and not using water. FYI the 5810 is set up for the 1.25 turbine meter.
One thing I notice is there are a lot of times when I check the current flow rate from the meter and it states it is about 0.3 GPM when it should read zero because no water has been used for a while. And sometimes it stays at 0.3GPM for a long time. I am thinking this is where most of the extra volume used is coming from. I am not leaking 200+ gallons a day. This situation is a little baffling for me as I would have naturally expected the flow to want to stop prematurely and/or under report. Not report 2-3x+ the expected water usage each day. The logical explanation would be a toilet leak, but nothing is running and my water meter and water bill do not support this.
I have removed the flow meter and inspected it. Everything looks okay. I have confirmed it even shows 0.3GPM even with the bypass engaged, and no flow is coming out the drain line when it shouldn't. I have also disconnected the flow meter connector from the board and it still reads a flow value when logically it should read zero. It baffles me why the flow meter reads a value when the pickup is completely disconnected from the board .
Does anyone have any suggestions for what could be the issue or stuff I should try to help you diagnose? One thing I have not yet done, but plan to is to put the softener into bypass overnight and reset the gallons used and check how many gallons it says was used overnight. I have also not removed the flow meter pickup from the housing body. I tried pulling it out but it was in there good and was not sure it there was a trick to removing it. I did not want to risk damaging it.
I would appreciate any help. I mean the system is working and softening the water, but it will want to regen way to often for how much water has actually gone through the system.
