Fleck 56SXT vs 5600SXT
HuffAZ
Phoenix
Currently shopping for a water softener. The controller appears to be a Fleck 56SXT. Most seem to talk about the 5600SXT. What is the difference between them?
Any recommendations for a water softener supplier in Phoenix, AZ area?
56SXT may be a dealer nomenclature-- possibly for a system, but the Fleck valve is the 5600SXT.
Would you be plumbing this with 3/4 inch pipe?
HuffAZ
Phoenix
Doesn't Pentair own Fleck? Pentair's website lists the 56SXT.
House has a softwater loop plumbed. Connections are 3/4"
Bannerman
Ontario, Canada
Pentair appears to have rebranded the Fleck 5600SXT as 56SXT.
The 5600 models are now called 5600 Electromechanical including the former Econominder metered model.
Ryan Symons
Dihydrogen monoxide specialist
Still a turd no matter what it's called. Spend a couple extra bucks for the 2510. You won't regret it
HuffAZ
Phoenix
Haven't heard many complaints on the 5600. Haven't seen anyone around here carry a water softener with the 2510. Usually the 5600 for smaller systems 1cf resin and the 7000 for larger.
They stopped making the 7000. The 5810 replaces that.
Ryan Symons
The 5600 is ok if you have decent water. No matter what you will be replacing pistons and seals at minimum 2-3 times as often in the 5600 as you will the 2500/1500/2510. That being said 5600 needs no special tools for the job like the 2510. ‍♂️
ditttohead
Water systems designer, R&D
Ontario California
While I am a huge fan of the 2510 and not that big of a fan of the 5600, I would disagree that the 5600 requires that much more maintenance. I worked with Pentair on the release of the 2510 and had one of the prototype valves in my house, working with both valves in heavy commercial applications, both valves were typically good for about 5-10 years in heavy use applications. Very similar in capability and performance. The 5600 econominder has had many issues with the 24 v motor, they did not last for decades like the 110 volt motors did. The 2510 almost never blows a motor since it is basically an industrial motor, completely overbuilt for the application. The 2510 had many issues with the neck o-ring collar, but that appears to have been corrected many years ago as I rarely sell this replacement part anymore. For residential applications I would definitely chose the 2510 over the 5600, but in all reality, the 5800 has really proven itself to be a great, reasonably priced replacement to both. The Clack valves are also excellent. I would say both of these valves surpass the 2510 unless you are looking for an 80's electromechanical non electronic design. Since the boards on the 5800 take about 10 seconds to replace should a problem ever occur, they are readily available and very low cost, not sure that it is that strong of an argument anymore.
So long as you stay away from the plethora of counterfeit and knockoff valves, stick with a real Fleck or Clack valve, you will do Ok. Also, way too many companies are putting Fake Fleck valves on junk from China. Stay away from the low cost online companies, most of these are not reputable. If the price seems to good to be true, it is probably junk.
