You want to vent the shower and toilet. Is this going to happen in fact with your proposal? Logic says yes. Is this going to be considered proper venting under IPC? I tend to think not, but I am not sure. AFAIK, wet venting is not allowed to mix with kitchen drainage.
That was the problem I was trying to fix.
Will the AAV between the lavs not serve the tub? If not, I'll just put an AAV after the tub trap, I had planned to do this in the first place but then for some reason I got the idea in my head that the AAV at the double fixture tee between the lavs would be all that is needed.
Does the toilet really need its own vent on top of the soil vent pipe? I don't know about the UPC, and not that I've seen a lot, but I've
never seen an additional vent for the toilet here, only the sink drain/SVP acting as vents. And I think functionally the AAV would serve the toilet as well if more venting was needed.
Can someone with more certainty tell me if I really need an additional AAV for the tub to satisfy the IPC?(and toilet I guess) Putting another after the trap for the tub isn't a big deal, but I'd rather leave the toilet alone.
Ah, the issue is that the tub drain can run between floor joists, while the toilet drain has to be lower to cross under the joists?
Yes.
So how far in plan is it from the (a) the toilet flange and (b) the bathtub overflow pipe to the soil pipe? Even better would be coordinates for all three points in plan.
Well, not exactly sure how to give directions here....but if you were standing in front of the lavatories(double) and looking at them represented NORTH, remembering that the soil pipe is almost directly below the sink on the right, the bathtub drain is almost directly 3 feet to the EAST of the soil pipe, not south or north at all really.....the toilet flange would be 8 feet 200 degrees south-southwest from the soil pipe.
As far as all that fitting mess, besides the concern about stacking two san-tees on top of each other, I just didn't know if a different configuration of fittings could solve the (at the time not known/understood to me) problem reach4 was concerned about....as far as stacking goes, its really a game of mm at that point, a quarter inch difference and precisely where the apexes occur could be the difference between fitting and not fitting, although I guess I could notch the joists though I'd rather not damage them at the edges....appears moot not anyways.
It looks like we are pretty much settled as far as the fitting goes(at least I am, unless someone else chimes in and says reach4 is right and whitney is wrong), I will use the triple san-tee. I appreciate the help very much, the only worry left in my mind is whether I need another AAV after the tub trap?
But, in case the above scenario occurs....is the drain the occurs after the AAV really considered a wet vent if the valve only serves fixtures behind it? Like I know in my set up its a wet vent for the tub...but its not a wet vent for the sinks, so if I put an AAV on the tub, would it still be a wet vent for the tub since now the tub has its own vent? Or is it a wet vent for the toilet? And the SVP is not considered the toilet vent but the sinks are?....Even then, the kitchen drain never really shares any pipe with the wet vent...
It looks like it would work fine either way, I would like everything to be up to code and definitely wouldn't want any egregious ones, but I'm fine with ambiguous ones as long as they work.
Thank both of you very much(and you as well Jeff).
