I read up on your filter so what you have starts out as 25 micron and goes down to 1 micron. I can replace my spin down element down to a 60 micron. But really, let's be honest here are there any health benefits of water filtered down to 1 micron? Is it better on the equipment perhaps? My suspicion is that anything below 100 microns probably passes thru the water softener. Are there any aesthetic differences of water filtered down that low?
I can't taste a difference. So why did I do it? Because I could, I guess. Before deciding to get my backwashing iron+sulfur filter, I ordered up 3 4.5x20 Pentek Big Blue filter housings and a bracket. I went ahead and had the plumber who installed my backwashing filter hook up the filters I had mounted to the wall. Way overkill, since the backwashing filter filters down to maybe roughly 5 microns. Maybe 10. Yet I have had a bit stuff of visible in the empty housing.
Initially I kept the first housing empty. Second housing was a 50-5 micron dual density. Third was a string filter that said 1 micron. About 13 months later I replaced those. The next time I went for the 2501 because it was cheaper than the string filter. I am probably losing some pressure, but its not bad.
If I were doing it from scratch, I might put one housing after the backwashing filter. Maybe one after the softener. If I had one after the softener, I would know if anything gets caught in it. A filter that does not catch anything is not worthless, because it tells you there was nothing visible to catch.
I don't have a bypass around my filters. I should. I keep extra O-rings because if I were changing a cartridge, and an O-ring was not reusable, I would be without water. Some filter housings have bypasses built in. That is a good feature.
After putting in my filtering, I flushed and cleaned the WH. The date code on the gas valve said it was about 9 years old. I got an impressive amount of dirt, sand and small rocks out. I think those rocks had not only come in from the well but had gone through the old Autotrol softener. After my filtering, no rocks or sand any visible particle could make it through.
https://terrylove.com/forums/index.php?threads/proper-gas-hot-water-tank-flushing.62015/#post-459818
