Joe88
Hi everyone,
I have a few questions I was hoping to get feedback on regarding a shower install I’m doing. The shower installed is an acrylic pan. I used concrete backer board for the walls which sit 1/8” above the shower flange. I used Redgard for the walls and a waterproof membrane strip for the gap between the backerboard and shower flange.
Before I tile I am looking to test that the shower walls are indeed water tight. Specifically, I want to test there are no leaks where the 1/8” gap is. I’ve read that the Redgard should not be treated as a wear item, i.e. don’t have a shower head pouring water on it. I was thinking of taping some painters plastic on the wall over the Redgard and running the shower so i can check that the gap is indeed water tight. Thoughts?
Also, my shower pan doesn’t come with any weep holes. I was considering leaving gaps in the silicone between the tile and shower pan, but I think that would create more issues than it would help. I’m thinking any water that does get behind the tile will dry via the grout? Any opinions?
Thanks for your help!
