Rush2828
This is probably a obvious simple fix but I wanted to ask for help from anyone with experience before I go an further. I broke my fawcet pipe last friday and it broke inside the brick wall of my pump house. It's loose when I try to move it from the outside but it's not moving on the inside. I've been chiseling on both sides to get the pipe loose so I can cut and fix it. Fixing the pipe is the easy part. I think if I clear out just the cement above and around the pipe it should ok and make it loose enough to cut the pipe loose. What should I do about the bricks and cement exactly?
Here are some pictures of the inside and outside.
